I have a 1992 Evinrude 150(te150glenc) that was having issues starting, it seemed to flood itself almost every time. Once it was running it stumbled a bit at idle but would run perfect at speed. I rebuilt the carbs using a rebuild kit and replaced the spark plugs and now it fires right up on the first try every time and idles great but when I'm in the water and throttle up to get on plane it acts as if its not getting enough fuel and bogs down and sometimes stalls but out of the water, in my driveway, it seems to run perect. I cant get the boat passed about 6mph. Ive taken the carbs apart 3 times to check float levels and they are good from the info that I have read(level with the carb body when closed).
Any ideas would be greatly appreciated!
