1992 bass tracker alarm keeps going off
92basstracker
I recently acquired a 1992 bass tracker and I've been having the issue of the boat alarm going off and a constant beep even when the motor is off. it stayed off for a couple days while I was working on it and today it came back on whenever the key ignition is turned on. I have researched and found that there is two reasons, one is overheated engine and second is low oil. neither of these are the case so I'm now stuck on what it could be. if anyone could give some information on it that would be helpful.
alldodge
Welcome
What motor do you have?
The alarm works by a ground being applied by either the temp or oil switches. When key is turned ON power is applied to one side of the alarm.
Find the oil and temp switches and disconnect wires one at a time until the alarm stops.
Grub54891
Had one at the shop several years ago, drove me nuts trying to figure it out. After testing and replacing mentioned parts, it was the alarm itself that was shorted. Weird causes sometimes.
92basstracker
Welcome
I have a 92' 90hp johnson 2 stroke.
92basstracker
should I run through tests or start with replacing the horn itself?
alldodge
Do the simple stuff first. Find the 2 switches, turn key ON and with alarm sounding, unhook each switch one at a time.
Moved to johnson
92basstracker
Moved to johnson
which two switches are you referring to? also where would I find the temp sensor on the motor, I'm assuming the oil sensor is in the tank its self.
alldodge
Temp will be a single wire switch (sensor) on the head. Oil should be on the tank and may have one or two wires, with one of the wires going to ground
Grub54891
Did it ever run low on oil? sometimes the sensor gets stuck down in the oil tank.
92basstracker
no, full oil always. the beeping went away for a little bit but then came back on when I switched my cranking battery and has stayed on since. I haven't ran the motor once since I did this and it is still staying on.
Crosbyman
back to basics... buzzers buzz because they are defective (it happens) or they are told to buzz by wires being chaffed or by defective "sensors"... finally because a problem is not fixed (cooling oiling etc..) .
try to find the wiring diagram feeding the buzzer or trace the wires back to their origin (heat sensor oil sensor etc..)
by convention heat sensor wires are tan color on the power head... oil well maybe tan or 2 wires has suggested on a float switch (check float) or some oil pressure sensing switch
disconnect them individually to see if the problem goes away
if not possible wiring problem ... inspect closely incl any connectors
if the problem buzzing stops possible bad sensor needs replacing or sensors are OK and a true problem exists in the engine....(cooling/ oiling)
Honorary Supreme Mariner
These buzzers have a wee circuit ( brain ) that sounds the alarm for 2/ 3 seconds when key is turned on.-----A self test so to speak.----That circuit can be defective.
