PBR Streetgang
Thread starter- Joined
- Mar 30, 2012
- 5
Hello, I have a 92 8hp Mercury Outboard that I have just acquired and it wont start. I have alot of knowledge on small engines but this one is throwing me for a loop. It has good spark on both cyl. It has just under 90psi compression for both cyl. and I put new plugs in it. I sprayed fuel in both cyl. and still no fire. I even cleaned the carb just to be on the safe side. I am assuming that it is a timing issue so I replaced the power pack, still wont start. I pulled the flywheel to check the key, its good too. I cant see how the stator could be doing this. I have no idea now.
