1992 70 H.P. Force cylinder pic (toast?)
BTAAA
From previous post. Cyl two no compression. Found piston damage, and what looks to be two possible cracks in cylinder wall. Can't tell if they are cracks in the sleeve or indentations caused by whatever was bouncing around inside. Can definitely dig fingernail in. Is this worth the trouble? Thanks
emoney
Re: 1992 70 H.P. Force cylinder pic (toast?)
I can see the 'cracks & nicks' you're talking about. The cracks are between the two holes and t he nicks line the bottom of the hole on the right, correct?
BTAAA
Yes, horizontal lines near the holes. That's about as far in as the camera would go.
Frank Acampora
The photo makes it really difficult to determine the of degree damage. I can see the nicks in the ports and the horizontal lines, but I can't see the condition of the cylinder below the ports and it looks suspicious.
Now: Worth repairing? Depends upon your definition, but usually yes. A boring job usually runs about 55-65 bucks a hole and pistons are about 125. You need only repair the affected cylinder.
If the cylinder liner is cracked, then new liners are available for somewhere around 100 bucks and it costs 200-300 to install them. But, a good used block could probably be scrounged up for around the same price. Unfortunately, (I think--depends upon year) the 70 uses a different front casing which incorporates the shift linkage mount so other three cylinder blocks can NOT be swapped in easily.
If the liner is not cracked, the nicks in the ports can be substantially removed by squaring the ports with a dremel and carbide bit. However, you want to do this on all three cylinders before having the bad one bored. The net effect will be a significant gain in horsepower with SLIGHTLY better mid range fuel economy. Of course, full throttle fuel economy will drop since it takes more gas to make more horsepower.
roncoop75
Look through the camera settings for a "macro" setting. If it's there, it would allow you to take reaaallly close up pictures. Well, if it's digital that is...
BTAAA
Thanks for the advice, but i'm not sure if I want to go through the trouble of re-sleeving it. If it were a simple re-hone I would do it. I fish alot, maybe it's time to replace it. I want to see what I can get for it as is. Someone may want it for parts.
