pontoon chief
Thread starter- Joined
- Aug 9, 2004
- 116
I have been working on a 1992 Evinrude that was kind of dropped in my lap to get running.Ugh.It had been sitting for some time and I was asked to mount it on the boat.
Mounting the motor was easier than getting it running.Ugh.After rebuilding the two carbs,I did manage to get the motor running,but it ran like junk.When it idled it would die,when it did run it would not stay running for any lenth of time,and adjusting the carbs did little to help the running.
I did manage to get the darn thing to run smooth,however it would not idle down to the point where it could be used.The RPM's stayed above 1500 RPM,which is not good for your lower end when placing it in gear.
I completely redid the link and sync and it still is not right,to the point when you start the motor with the throttle raised,as that is the only way the thing starts,the motor goes into the old "runaway" mode,and darn near melts down.Did that twice,and I gave up.
At a loss here guys,any ideas ?
