1992 40 hp Force overheating problem...
Gooch
...my father and I took the lower unit off thinking that maybe the impeller was bad but it looks<br />just fine. In fact, my dad took it to a repair shop for a mechanic to look at and he said that <br />there is nothing wrong with it. The mechanic then suggested that maybe the thermostat isn't<br />working properly (sand buildup?) which could cause the problem. So, a week later we pulled <br />the thermostat and there was some corrosion but that was it. Regardless, we then started the <br />motor without the thermostat and still weren't getting any water to spit out of the exhaust <br />holes. Now we are stumped. If the impeller is fine and the thermostat isn't the cause then <br />what could it be? Any help would be greatly appreciated. :confused:
flabound11
Re: 1992 40 hp Force overheating problem...
I had a Force 120 with the same problem, I took the manifold off to find a piece of trash blocking the water outlet hole. This stopped the water from being able to exit the motor thus causing it to over heat. Hope this helps<br /><br />C
Gooch
How difficult is it to take the manifold off?
flabound11
It wasn't a hard task on the 120, I can't answer how hard the 40 will be. If you don't have one already I would suggest getting a manual, it should explain how to do this task step by step<br /><br />C
brother chris
Well I had the same problem with my ob, and before I did anything like taking it apart, my friend grabbed a hose and turned it on and put it to the outlet. It now runs great with alot of water gushing out of the outlet. Maybe that will help....
