1992 4.3 Mercruiser, Alph1 Gen II drive
BOWTECH.JUSTICE
Had boat out and things were good. Stopped to change tubers and once I got moving again there was no response from the trim. No click or anything. Neither the trim or the trailer button does anything. Is there a fuse that could be blown? and is that fuse in-line with the wires by the trim unit?
Bt Doctur
that fuse does power the relays, but the relays get there main power from the heavy red and black wires , loose/corroded connections could cause no power
BOWTECH.JUSTICE
I found the fuse and it was blown. Did check the connections also and they look good. Thanks for the response.
