1970Mach1
Thread starter- Joined
- Aug 2, 2010
- 71
Hey you guys! Looking for some advice here. I have been getting water in my oil on my 1992 3.0 Mercruiser. Here's where it gets tough, the oil was milky so I changed it the beginning of the year and keep a eye on it. It was fine the first couple times I've taken it out. Then I noticed it again this weekend. I changed the oil again and took it out for a couple hours and it didn't have a drop of water in it. So its intermediate. I'm kinda thinking the water gets in it when i run it with earmuffs on but can't say for sure, or when it gets hot but can't say for sure why it didn't get water in it all day on the 4th of July. I have a crappy idle after the boat warms up, she will buck and chuck until you crack the throttle like three times to clear it out. It's been like that for 2 years now, haven't figure that out yet, unless it's getting water in the intake...
So I've pressurized the coolant system, took off the hose that goes to the outdrive and plugged it, took off the hose to the exhaust manifold and pressurize that. It has had about 15psi in it for about 24 hours now.
What would you do next? Tear into the exhaust manifold and riser to look at it? With it not getting water in it all the time makes it tough to track down.
Thanks!
Thanks!
