1992 25hp evinrude high end surging
Justbananas24
Motor will start surging after trolling for extended period of time! Other than that it seems to be a really good running motor. We have tried to pump the bulb and disconnect/reconnect the fuel line while surging with no luck.
flyingscott
When that happens try adjusting the low speed needle a little richer or leaner which ever works I am guessing it needs to go richer.
oldboat1
For h.s. surging after extended trolling, it sounds like you might be loading up -- would pull the plugs and clean them up if blackened. Might do some research on plug choices, and see if there is a solution there.
Fine tune low speed operation for best efficiency -- just the usual. Make sure the carb is clean, and motor runs smoothly low and slow -- look for lean setting without stalling or lean sneeze. And it may be that your 35 isn't suited to troll as slow as you want -- may want to consider other options. A lower pitched prop will hold down speed while allowing higher rpms (but loses top end speed when heading home.) A small trolling motor can be a solution (also nice to have a get-me-home motor). And you might try back trolling (not much experience with it, but might be able to operate at higher rpms). Not sure if back trolling has adverse effects on motor, so would research first.
