I went fishing the other day and the motor ran fine on the way out there. When I tried to start it to return it would spin over but not start. When I first crank the motor it will kind of start for about two seconds. It sounds like it will hit on a couple of cylinders but then die. So it must be getting spark for a short time? Any suggestions where I should start? I just changed the rectifier/regulator about a month ago.
