1992 150 V6 60degree want idle right
smbass577
My engine will start fine, but only run at very low speed when put in gear. Between 700-1100rpm's the engine cuts out and quits running. I can restart the engine and it runs fine utill I put it in gear but repeats the above. If I put it in gear and give it full throttle the engine runs fine. I have had the carbs rebuilt and the theromastat on one side replaced. this did not help.
Dhadley
Re: 1992 150 V6 60degree want idle right
Sounds like the shift interrupter switch may be out of adjustment. <br /><br />Good luck!
AUGIDAWG
It sounds like your idle mixture screws are too lean. Try turning them out counterclockwise 1/2 turn.
