1991 mercury 150 outboard black max
Weekendpass
This my first post and lneed help with my engine it's a 1991 mercury 150hp black max, rebuild the carbs and reed values and I am having trouble with it idling and shuts off when trying to put it in Gear, now it want crank up for long without shutting down a to like it not getting gas.
Any suggestions need help.
Chris1956
Honorary Supreme Mariner
You might repost this in the Mercury OB forum. They will ask you for compression numbers and spark on all 6 cylinders.
Chris1956
Great, tell it to the Mercury OB forum guys/gals. They will want numbers, though.....
Dukedog
first of all, "why did you get (decide ta work on it) into tha motor ta start with???".. when you rebuilt tha carbs were new gaskets used throughout including new accel. pump parts?.. was a link n sycn and timing done?... does it help if primer bulb is pumped when trying ta keep it running?.. did you use a manual (0em) with whats been done or was it justa "wing-it" done thing?
