Just did a powerhead rebuild on the engine. Still needs the timing adjusted, have to take it in as I don't have a test tank or prop for it. Engine is running good, rough starting at times as I'm running mixed gas with the VRO as I don't know if its efficiently running oil in. (reason for the rebuild? I don't know yet) The tach was working fine, after a few hours on the motor I opened it up a bit, RPM passed the 7 grand mark on the tachometer, (was not near full throttle). Now the tach is not operating correctly at all. Replaced the stator. Still not working correctly. This is my first rebuild, I've learned a great deal from these forums and I thank you all for the questions and answers that have been given to me already through this process.
