1991 Johnson 225 tilt and trim issues
jpburks
Hello everyone,
I bout a boat about 2 months ago and ever since I bought it, it has been having tilt and trin issues. For some reason, it only works intermittently annd will work more often when the motor is running. I know it isn't the batteries or powerbox, because batteries are amazing and power box relays both click when supplied power through applicable switch. It does work sometimes, but last Sunday it quit and I had to use the Manual Release to get the motor off of the chock. Then when I got home, it worked fine. I am not sure if it is electrical or if I just need a new pump of fluid or what. Please help. :confused:
