1991 Johnson 150 Question regarding tuning and no exhaust housing
w2much
As the title implies Going to put the lower unit back on and realized that it never had a lower inner exhaust housing. When I ran the motor a few times in the past in a test barrel I thought it a bit loud but just figured it was an older motor and the sound blankets were not in the cowl. Any way I now realize there never was an inner exhaust housing. Brings me to question why I could not get the idle right. No back pressure? On my 1995 150 I needed to run it under unrestricted load in gear to get the carbs right. Messed with this one for a while, cleaned the carbs, got the timing right it just never had a so smooth idle. Am I correct to assume that once an exhaust housing is installed my idle issues may also be solved? After adjustment of course.
Faztbullet
Its gotta have one or powerhead wouldn't bolt on....I suspect your talking about exhaust "shoe" that fits on exhaust can between mid section and lower.
w2much
1991 TJ150SLEIE Parts diagram #22, Exhaust housing ,inner lower. It certainly looks like a shoe.Sorry for the confusion.I ordered one which I hope to receive next week. Might it have been left out for any reason you might think of.( Besides a mistake or liking the sound)? But really I am curious of the idle, performance issue.
w2much
I thought the back pressure would be so much lower that the tuning would be affected. Actually I was hoping for that reply. I will post when done next week.
I think that part fell out of the midsection, when I was changing the impeller. I stuck it back in with grease or caulk.
