1991 Johnson 120hp v4 stalling and erratic idle
Rooboo
I just purchased a boat that came with a 1991 Johnson 120hp outboard. Model #J120TLAIE. Previous owner said that there was a running issue. He said that he had the carbs professionally cleaned, but the problem was not fixed. He also had installed a new battery, spark plugs, and plug wires. I took the boat out on the water and it seems to run good at wot, but the idle is very erratic and has a tendency to stall. Most of the linkage adjustments were all messed up and I have them somewhat closer to where they should be. I put a timing light on it and noticed that the #1 and #4 cylinders were not firing consistently. While resetting the timing, I noticed that the #1 cylinder spark was jumping 180 degrees out of time. I did a few tests following the cdi electronics diagnostics, but their were a few tests that I didn't fully understand. I suspect that the power pack is bad, but I would like to confirm that I'm not missing something else. I have swapped the coils around, but nothing changed. Any productive input would be appreciated.
Thanks
Looked into crankcase compression issues ?------Also post the cylinder compression numbers here.
Rooboo
I have an ignition problem, not a compression problem. Looking for someone that fully understands the diagnosis of the power pack, timer base, stator, and rectifier.
Just install a new powerpack.----Will fix that problem 8 out of 10 times.
Rooboo
What about the other 2 times? I prefer to be accurate, rather than playing the odds. I'm not ready to load the parts cannon just yet.
iggyw1
Ensign
Good luck with the engine. Should listen to the gurus on this site.
