1991 Johnson 100hp V4 - Prop Size
mccollum74
What prop is recommended for a V4 Johnson 100hp 1991 model on a 17' Skeeter F/S. The boat is used for pulling tubers and skier's mostly. I don't know what is on it now. It also have a dolphin on the motor.
Texasmark
Re: 1991 Johnson 100hp V4 - Prop Size
Go to the Michigan Wheel www. Plug in your numbers and they will tell you. Whatever they say, I'd drop a couple of inches of pitch to help your towing....they don't know you are doing what you are doing with your boat.
HTH,
Mark
Bob_VT
Get yourself a 17" pitch 3 blade and you should be fine. It should be the best all around.
