1991 jesus chrysler force 150
Bradforce
The Force is not with me!!! I have a 1991 Force 150. I have replaced just about everything including the starter I can not get motor to fire It only has spark on 1 cylinder Can someone help please Thanks A desparate boater Brad
Bradforce
Re: 1991 jesus chrysler force 150
The engine has the Thunderbolt ignition.
The top cylinder is the only one getting spark, and it's alot of strong blue, snapping arcs jumping a 7/16" gap.
It seems like this cylinder is getting the spark meant for the other cylinders.
I measured the resistance of the triggers and they are all within spec at 1250 ohms.
I swapped ignition coil wires, all coils spark when the input from the top cylinder is connected to them.
I suspect that the switch box is bad.
Any input would be appreciated.
