BarryK3
Thread starter- Joined
- Dec 6, 2017
- 48
Hi all,
The motor developed a new problem today. The engine quit while going slowly in the harbor. I pumped bulb about 5 or 6 times until hard, then it restarted fine. It quit again after about 2 minutes. I had to do this repeatedly to limp back to the boat ramp. Earlier in the day it ran fine at WOT, 35 mph as usual. The rpm increases prior to quitting, like it is lean just before running out of fuel. It takes quite a few pumps until the bulb gets hard which implies to me that the carb bowls are empty.
The bulb does not go flat, so I assume it is not a restriction at the fuel tank inlet. No fuel leaks, bulb gets hard.
I checked the screen in the fuel pump and there was only minimal debri. I don't have a fuel filter or water separator. I recently replaced the pump bulb and fuel lines.
I assume it is a fuel pump problem? Is any other troubleshooting needed before replacing the diaphragm and gaskets?
Thanks,
Barry
Thanks,
Barry
