1991 Force 120hp l-drive Wont Start
xxsoloxx98
Hi Everyone
Force 120hp l-drive. went out last night started ran everething fine went to stop lowered throtle almost in neutral engine shut off went to start nothing has fuel turns over (doesn't start) changed spark plugs checked each coil none of them has a spark so am guessing its electrical problem checked all wires ground everething fine friend told me its something underheath fly wheel or some power pack i have no idea anyone has any clue i would greatfully appreciate it.:confused::confused:
roscoe
Re: 1991 Force 120hp l-drive Wont Start
Stator may have failed or has a broken wire.
Not likely the trigger, but possible.
Also not likely that both cd modules failed at the same moment.
Quite possible that the kill switch or related wires have grounded out the ignition.
xxsoloxx98
Thank you Rosco do you or anyone know how to eliminate the emergency shut off switch or the kill switch thank you
any other ideas anyone???? thank you
