Darren Smith
Thread starter- Joined
- Mar 25, 2005
- 135
After reading the old posts I found one on Turning Point hub kits but not one for Michigan Wheel. So here's the deal, My prop got messed up, So I had a freind bring one back from the U.S. The one he got was a Vortex XHS, part 992106 (or something like that, the numbers arent' in front of me). Now since this is a twin engine, I think I should have matching props on each engine. So I found the hub kit for the 95 and up Force, but I have a 91. I was reading the West Marine catalog, under the Rapture series of props, it says to use hub kit 102 with a thrust washer 23-819057 again, don't quote numbers, I left the papers at home, and can't get online at home). Has anyone tried this set up to se if it works? I have the original thrust washer Force part 660869, is it the same as the Merc thrust washer?<br /><br />Sorry for the long story, but trying to give as much info as possible. As always thank you for any replies!
