1991 Evinrude 30HP - Oil Behind Starter Motor
Tacorog
I have had this for around 3 years and this year two new issues appeared. There is an oily substance behind the starter motor above the carb. I cannot identify where it is actually coming from. However since it appeared at this level the engine has become quite cumbersome to get started. Once running its as smooth as can be. I am not sure if these two are related, but open to any ideas.
Honorary Supreme Mariner
Check / replace the oil recirculation hose.-----Also check the mounting bolts for the starter motor.
Crosbyman
just for my info.. your carb seems different than the parts diag. for EV 30hp 1991
what is your eng. mdl # ??
