Hello.
I need some help trouble shooting. This is a 1991 Evinrude 175hp outboard.
The motor is not charging my batteries. With the motor off I get 11.8 V it the batteries, and with it running there is no change.
My tach is also not working.
I need some help testing if it is the voltage regulator or the stator.
So far the only test I tried was to read the OHMS from the 2 YELLOW wires coming from the stator at the plus where they into the plug at the voltage regulator. My results are 0 OHMS.
Is this the correct test to test the stator? How do I test the voltage regulator.
Anyone have a manual for this motor they could email me?
Thank you
Thank you
