1991 Evinrude 150 Xp V-6 Issues
petie24mn
Here is my situation, I have a 150 V-6 (xp) and it has been running rough in the 1500 RPM-2000RPm Range, so I decided to check the plugs, and do a quick once over, replaced the plugs, because they where fouled, replaced the fuel line because it was dry cracked, and cleaned the carbs. Took it back to the lake and ran it again, still the same problem, I have heard that stators and timing sensors go out in these so I looked under the flywheel and noticed after getting off the lake that the epoxy on the stator was melting and dripping down onto the top of the power head, so I proceeded to replace the stator, and timing sensor figuring that was the problem, and I also checked the voltage output to make sure the regulator wasn't bad, max output voltage was 14.7 volts. So after replacing these parts, I went back to the lake, and still the same problem?? The motor runs great on top end but if I am idling it around or hold it in that 1500-2000 rpm range where it is running rough, it will die if I suddenly shift it to neutral, or if it does stay running it dies if i shift it into reverse, then it will start back up and do the same thing.
I sprayed carb cleaner around the power head to see if I have any leaks, and I sprayed around the throttle shafts on the carbs to see if they where leaking and nothing happened. I am getting frustrated and would like to see if anyone out there has encountered this type of problem? Any help would be greatly appreciated!
jogle1023
Re: 1991 Evinrude 150 Xp V-6 Issues
You need to check your coils. 1 of them is miss firing.
emdsapmgr
If it's been a while since the carbs were overhauled, you might find that overhauling them may solve the problem. There are three types of jets in that engine, idle, mid and high speed. Possible that you may have some dried fuel (or even debris) in one of the carb jets or passages, causing your problem. When disassembled, a spray can of carb cleaner will tell you if all the jet passages are flowing properly. I'd pull all the jets and examine the orfices closely, then reinstall.
petie24mn
I already have removed the carbs, cleaned them, and all of the jets, that didn't help.
clanton
Check the pack output to the ignition coils, at cranking rpms, then with engine running at idle. Check back of coils for arcing to metal plate that covers the pack.
emdsapmgr
Take a timing light with you next time you go boating. When you are at the rough rpm range, put the timing light on each plug wire. You are looking for strong, ryhthmic flashes from the timing light. You should be able to tell if you have a misfire from the flashes. If everything check ok, check your idle timing. It could be too low.
spicerak
why dont u try to do a de carb that might work do 3 cans and let it sit for 3 hours
basserjim2
How does engine at higher rpm..( run on top end)? Can you smell fuel? running rich? Have you choked the engine while running rough? does that help?
petie24mn
The engine runs great above 2000 RPM, and it seemed like it would run better when the motor was trimmed up about half way, the engine would increase in rpm, so I took the carbs back off and checked the float measurements, and adjusted them to the lowest adjustment the booked called for. it seemed that it was flooding the engine out when the motor was trimmed all the way down, but it still will die out on me when I run it in that 1500-2000 rpm range and shift it to neutral. I am going to try a timing light next and check the coil packs.
Dhadley
Setting the floats low can be hazardus to the motor's health. Set the floats parallel. If the carbs flood out with the motor down, something else is wrong. If the motor is sitting pretty low in the water, like on a bass boat, it may indeed pick up some rpm as you tilt it because it looses backpressure as it come up.
