1991 Evindrude 60 HP struggles to idle, setting maxed out
yok
Anyone have some ideas or suggestions as to why my OB struggles to idle?
The motor can stay running at about 1,000 RPMs, but when returned to idle it dies quickly when cold and eventually when warmed. I'd adjust the idle screw, but it's screwed all the way in.
strokendiesel002
Do you by chance have the service manual? I'm not sure what the factory recommended settings are to start, but if you're maxed out/ then it's probably time to pull, clean and possibly install a rebuild kit. You should have 3 carbs, correct? I think they're something like $30/ kit.
If you've already rebuilt them and now you're having this issue, and you have the primer system (my '93 Evin 60 has the primer) I'd strongly recommend replacing the 3 lines that go from the primer solenoid to the intakes. I had 1 leak last year after fixing the solenoid and it was hard to start, didn't want to idle down and would "diesel" after shutting off the key. Replaced those 3 lines and it ran much better.
It's important to note though, that I found out about those lines because my primer solenoid failed. One day in the middle of the season, it just quite working correctly. Before buying all sorts of parts, it's of utmost importance to make sure that correct settings are tried.
Good luck!
yok
jakedaawg, I'll have to get a compression & spark tester and I'll post. I'm assuming to look for ~120+psi/barrel?
strokendiesel002, no service manual that I know of. Is there a downloadable .pdf for it?
Correct, it's a 3 barrel carb.
Found a schematic of primer lines, but only gives one PN. VE60TLEIB
www+marineengine+com/parts/johnson-evinrude-parts.php?year=1991&hp=60&model=VE60TLEIB&manufacturer=Evinrude&section=Electric+Primer+System
PN: 333387 - HOSE, Primer to fuel Tee, 4"
I wonder if I can get a long tube of it and just cut to size? Cheap enough to eliminate as an issue.
strokendiesel002
Yea, I wound up buying a 25' roll, I'll check tonight to see what it was that I bought and let you know!
yok
I think I found some extra (~1') hose to use. Also now have a compression tester.
Honorary Supreme Mariner
Does the hose for the tell tale come off the side off the block or has it been rerouted to the top of the block ?
yok
I'm not sure what you mean by tell tale, but everything is stock so no rerouting has been done.
