a bit of a wierd one. Last time i had the boat out it was hard to start but did eventually start. Was just winterizing this weekend and could not get it started. The engine cranks fine but will just not fire up. The plugs were not really wet (as i would expect from trying to start) but the bulb was hard ( I also tried diconecting the gas line where it goes into the engine and got that little spray so fuel supply was there) and the carbs had gas (i know that because i eventually gave up starting and drained the carbs and just sprayed fogging oil in the cylinders to winterize and changed gear oil etc.). I noticed oil or gas mixed in with the water comming down the driveway from the water ears to start the motor on the driveway. I tried checking for spark but could not get a spark ( i took another plug and grounded to the motor). Verrrryyy confused. i did check that there was power to the 3 red wires going to the terminalls near the coil. can anyone make any suggestions.
