1991 60deg 175 recirculation check valve
skimmabird
1991 60deg 175 recirculation check valve replacement
I have one that I want to replace that has a hole in the seal and it leaks. The 1991 schematic isn't to great with id'ing the check valves, and it looks like they say only 3 are required. It looks like the part # is 394884, they say 3 are required and it's $46. Something doesn't seem right about that. The later motor's schematics seem to id them better and have the correct qty and the are cheap. What part# can I use to get one and are they just lightly pressed in behind the bronze insert. I assume I can put one in and out instead of the machine shop?
