Are automotive 5.0/5.7 oil pans the same as merc,.. interchangeable ? thank you
shaw520 Chief Petty Officer Joined Aug 27, 2009 Messages 634 Apr 24, 2011 #1 Are automotive 5.0/5.7 oil pans the same as merc,.. interchangeable ? thank you
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,473 Apr 24, 2011 #2 Re: 1991 5.0 oil pan Ayuh,... Merc has used Many,... Most differences usually deal with the Dipstick placement....
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,511 Apr 24, 2011 #3 Re: 1991 5.0 oil pan Yes and No, auto pans fit the bolt pattern but will need the baffel removed first.
shaw520 Chief Petty Officer Joined Aug 27, 2009 Messages 634 Apr 24, 2011 #4 Re: 1991 5.0 oil pan thank you,.. So I can get an automotive pan cut out the baffel,..and save a bunch of money.
