Re: 1991 40HP Evinrude
Sounds as if you have a fuel supply problem. If it works OK after idling for some time but shows problems after a few seconds, it may be a sign of insufficient supply to the carb's bowls (when full it works OK but as soon as the motor uses more than idle-amount, the bowl drains and the motor 'runs dry'). Make sure the vent in the tank (cap) is OK - test by removing the cap while under way. If used fuel cannot be replaced by air, a vacuum will build up in the tank and the fuel pump can't overcome this.<br /><br />If no better, pump the bulb to help the fuel pump when the problem occurs, to see if this helps.<br /><br />If the extra bulb-pumping helps, your motor's fuel lines (and filter) should be looked over for leaks and overall condition. The fuel pump may need a kit (new internal parts for the pump).
