Hi there. I have a 1991 tracker super 17pro that has a 1991 evinrude 40hp outboard model TE40ELEIA on it and it is not running right. It acts like it is a fuel related problem. When i hook up the hose it will start and run for a while but then die. When i took it to a lake we go to it will not start at all. I replaced the fuel filter and primer solenoid and put new spark plugs in it as well. The person i bought it from said he replaced the fuel tank and the hose that leads into the motor. I found i had a couple of loose hose connections so i tighten them up but still not running right. I checked my pressure on my ball on the hose and it wont stay firm as well. If any one has ideas that can help me out i would appreciate it alot. Thank you.
