1991 35hp Force will not open up to full throtle
billt
My 1991 35hp force runs good at idle and willrun at about half throtle will not go into high throtle sometimes it will open up to full rpm PLEASE reply
roscoe
Re: 1991 35hp Force will not open up to full throtle
As always when a problem pops up, check for spark on both plugs, clean and regap the plugs, check compression, check fuel filter for restrictions/dirt, check to see if the ignition is advancing as you turn up the throttle, check to see if the carb butterfly is opening.<br /><br />Try squirting some fuel ( use a small spray bottle ) into the carb as you try to go full throttle, does the engine accellerate with this extra gas?<br /><br />If these check out ok, I would rebuild/clean the carb.
