1991 25HP Evinrude Running Issues
cgilcher
I have a 1991 TE25ELEID Evinrude that I cannot figure our for the life of me. The motor runs great for 5-10 minutes and then falls on its face. Its spit, sputters, and pops at mid to full throttle. You bring the motor back to idle and it runs like it should. If you turn it off and wait a few minutes you can get another minute or two of proper running at mid to full throttle and the problem starts all over again. The motor always starts easily and idles nicely. Here is what I have done so far:
1. New fuel pump
2. Rebuilt with Evinrude Kit and cleaned carburetor - Set float parallel with gasket surface
3. Brand new primer bulb, fuel lines, vacuum lines, hose fittings, etc.
4. Newer fuel tank - Purchased a few years ago
5. New ignition coils
6. New spark plugs
Ive done several tests to try to troubleshoot the issue. The primer bulb always stays full, tight, and vertical. The fuel tank is vented. I pulled the tank lid off while it was having issues and it did not change. The water pump seems to be pumping plenty of water. I can place my hand on the back of the engine with no problem. I took my temperature gun out with my one day and measured around 125 degrees at several points at the rear of the engine. Ive unplugged the temperature sensor with no change. Ive checked compression on both cylinders. The top cylinder was 130 PSI and the bottom was at 127 PSI.
I took my father out with me today who is an experienced (large) natural gas engine mechanic. We placed a timing light on it and observed the strobe. The pulse looked great while it was running good but we did notice some change when it started running poorly. He seems to think it is an ignition issue. Id be willing to bet that all of the ignition system components are original to the engine. I wanted to get some of your thoughts before I sink more money into this thing.
Thank you in advance!!!
cgilcher
Thank you for the information. I spoke with my local Evinrude Dealership/Service Dept. today. He led me in the same direction as that it may be a powerpack issue. He said that powerpack failure is a common occurrence with these engines. I asked him about the stators in these motors. He told me that stator problems occurred more on Mercury vs. Evinrude but didnt rule out the possibility that this could be an issue. Upon his suggestion I purchased a powerpack. Hopefully that fixes it.
Thanks!
G
Guest
Guest
Those go without warning unfortunately, I was 15 miles down river when my '93 25 E died without warning,at least yours is letting you know.
