Re: 1991 225 Yamaha drops 700 RPM's
OK,
I've replaced the caps. On test run, it cranked-up and idled smoother, but on excelleration it was under powered (like it was on 5 cylinders again). After 2 /3 min. it would jump from 4600 RPM to 5200 and then back. Then it started running at 5200/5300 at full trottle. Problem still intermittent, but smoother!!!
I've just ordered a new crank position sensor.
Scott,
how do you check the valve's you were talking about without removing them?
your intermitant problem on a good chance could be a fouled plug!.......i would look at replacing them after you check the valves....
To check them there is the easy nasty way.
Go to the nipple that is on the side of the reed block this nipple will have TWO tubes connected to it, one tube leads to the nipple on the intake manifold and the other leads to the one way valve on the cylinder block......disconnect the one that goes to the check valve and place into your mouth and blow first!!!.....then suck back on it.......if air flows both ways the valve needs replacing!!!.....you might get a bit of fuel juice in ya mouth ...thats the nasty bit lol.....a cup of coffee will fix that lol.....
remember if you find that you need to replace them make sure that the same tube gets connected to the same cylinder it was disconnected from No1 cylinder check valve is NOT line connected to No1 carby.......there is a special sequence....the best way is to do it is one at a time...(disconnect..remove and replace valve then reconnect the tube and move on to the next one)
I personally would do all this and replace the plugs before running the boat again....that way you then can test your top end issue properly.......
If you find that after all this you are still fouling plugs especially the port side bank plugs then its more than likely the oil pump shaft seals need replacing!
I went through the same issues as you did last season and have since rectified the problem by doing all this and replacing all these parts.....motor is running sweet as a nut now.......PM me if you need more help or tips
