1991 150HP
budgie
G'day from Aus, Can anyone help with photos of the gear cable setup on a 1991 force 150hp,right side of motor. I am fitting with a standard morse cable but the shift ends up backwards, i think there might be a pivot point. Cheers Budgie
force01
Re: 1991 150HP
budgie<br /><br />it sounds like you are using the wrong control box for your set up , some control boxes give you the option on which way the shift arm swings.basically the shift arm would have to mount 180 degrees from were it is right now and there would also be a different location to mount the cable do you have this option goodluck bret If you need further assistance please email me @ forcepower01@yahoo.com. thanks,Bret
