I purchased a 1990 cv40eld outboard knowing that it needed lower unit work. The lower unit was in pieces in a box when I purchased it. The previous owner didn't want to put any more $$ into this project pontoon. The only problem I could find was the lower driveshaft needle bearing was shot. All other bearings and gears looked good. I removed the race for the top bearing and then the drive shaft sleeve, which was plastic. There seems to be an aluminum sleeve in the bore as well which is preventing me from being able to drive out the needle bearing. Am I missing something, I can't see how to do it without removing this aluminum sleeve and I cant figure how to get it out. Any advise would be appreciated.
