Ok pulled the carbs both apart, they were extremely clean as I expected being rebuilt 2 months ago, went ahead and cleaned all passages, jets, everything, put back together, set idle at 1 and 1 half turn out, it was way way way better for about 10 minutes, then starred running normally then like it would miss a couple times then recover, found a few cracked fuel lines replaced all of those inside the motor... still just runs great for 20 seconds then misses a couple times and catches idle again for 20 seconds... checked compression it's great on both cylinders... guide me!
