1990 Suzuki DT 150 issues
kboyd2
Hey Guys,
Need some help. I have a 1990 Suzuki DT150, and it loses power under load. I have figured out that it lost spark on one side. So I disconnected the low oil warning reset module, which fixed that. I then changed all the spark plugs, cleaned carbs. I then had an overheat problem, turns out that the water flow sensor on the right side was broken and a piece of the sensor jammed up the thermostat. So I fixed that. Now it starts better, runs better. But I just cant get it to plain out. If I get my stepson to sit on the front, it'll plain out, slowly. but even when I am in it myself, it wont plain out or takes about a minute of full throttle to plain.
Any suggestions?????
