1990 SP-A CD Trim Reverse Lockout
steiger23
Outdrive kicks up in reverse so assume lockout is in trouble. Having trouble finding any info or even parts diagram on internet for this particular type. What should I look for short of removing entire outdrive?
Fishermark
If yours is like mine, then it is all mechanical linkage up under the outdrive. The various parts and connections can get stuck and corroded. Not too difficult to take apart and clean. Then it should work fine.
steiger23
Correct, outdrive does NOT have to be removed to replace the 4 springs as i found out firsthand. See a few pics on my blog: steigercraft23.blogspot.com.
jerryjerry05
The fix can be done with the drive on.
​The lock or spring hook can be bad and need replacing.
You need to see if it just needs cleaning or replacing.
The parts from Volvo start at $100 and go up.
Some can be found on e-bay but make sure you get the right sides??
There is a L and a R.
This site has a link to the Volvo parts you'll need.
