1990 outboard evi rude 40 ,low rpms
Lplp52
I have a 40 hp ,warm up lever I can rev up to over 5000rpm ,but if in gear I can only get 3000 rpm max ,is there an adjustment I am not seeing ,compreesion is good .
Honorary Supreme Mariner
And what is the compression ?-----They will all rev up in neutral even on one cylinder !------Sounds like it only is running on 1 cylinder.---Test for spark.
Lplp52
Changed the coil also and thermostat ,new plugs ,disconnected the thermostat wire also ,and I think it is only on 1 clyd now that you say that ,makes sense ,.
can't check until upcoming weekend ,so thinking it is the cdi now.
Some organized trouble shooting will find the problem area.----Guessing gets expensive in a hurry.
