andrewgroup
- Aug 23, 2003
- 115
I just had a power problem this weekend (BAD BATTERY CONNECTIONS). TOday though the tilt up simply clicked. I cleaned the two additional wire rings that feed the two 50amp fuses, when I cleaned the battery post clamps. I'm going to revisit this tommorrow evening but would like some suggestions on this topic. I've searched the forums and found only a few comments about this problem. When I had the power problem at the lake, (NO TOOLS, yuk) I removed the long bolt at the ends of the hydaulic lifters and blocked up the outdrive. The next day I cleaned the batteries and I did operate the outdrive switch with no load on the hydaulic lifters. Could I be in a situation that requires bleeding or something similar.<br /><br />I suspect I still have bad power going to the motor. Any comments or suggestions greatly appreciated.
