genuinegemini
- Mar 22, 2012
- 35
Re: 1990 OMC 4.3L Equivalent and Swap Complexity???
Okay, I took some measurements and this is what I came up with. The i.d. of the original manifold riser outlet, is 3" which dumps into a 4" coupler connected by a couple boots or bellows. The angle of the original riser is 30 degrees, and I can get a 30 degree riser for the new manifold. The i.d. of the new riser is less than 3", but the o.d. is 3", but I'm not sure if the smaller i.d. is enough to cause concern. The only accessories on the original manifold are the water inlet from the thermostat housing and the pitcock drain, both of which are on the new manifold. The only change is that the port inlet will be on the backside of the manifold instead of on the front. I think I could live with that. Any comments, details I may be missing?? I really do appreciate all the insight, fellas. Your knowledge and expertise is invaluable, to me. Thanks!!
Your problem is adapting from the outlet of these new risers to the inlet of the Y-pipe if the diameters are different. That is what Bondo is saying.
