I had to pull the motor out due to a rotten board under the front engine mount, and a failed engine / driveshaft coupler. I installed a new coupler, new points, cap, rotor, wires, plugs, fuel filters, fuel lines, fuel pump gasket, valve cover gasket, carb and exhaust manifold gaskets, main belt, and lower unit water pump. Also adjusted the vavles by following the factory specs on those. After putting her all back together, I am having 2 issues:
1. First problem is the enging idles very rough, even at 1000 RPM. I have followed other threads about setting the idle and needle valve, and have meesed with both on the water and on the hose, but can not get a smooth start or idle. What am I missing?
2. Second problem is that the motor previously ran up to 44-4500 RPM, now I can only get 38-4000. It does run smooth once up and going, just slower and less RPM than a few weeks ago. Good compression on all 4, just over 130PSI.
Any suggestions?
Thanks
Kirk
Any suggestions?
Thanks
Kirk
