1990 Mercruiser 4.3..... rpm and speed Problem...
henry7o7
hello,
I have a 1990 dynasty cuddy cabin.. I got this boat and took it out on a test run.. It runs great.. 40plus MPH @ 4800 RPM...
it has been sitting for about a year so decided to replace some parts...
Replaced impeller... ignition cap... ignition rotor... ignition sensor (located inside cap) ... thermostat ...
Took it out for a test run and when i put it into gear and go.. it doesn't plan fast well not at all.. does about 30mph after about 2 mins of going.. wot and only does about 3000 rpm..
ANY HELP??? :confused::confused:
90stingray
Re: 1990 Mercruiser 4.3..... rpm and speed Problem...
You get a plug wire crossed? Double check everything.
henry7o7
plug wires correct.. with no load (not in gear) the engine runs fine..
fuzzybob
Henry, At the top of the forum in the "Adults Only" sticky there is a link that lists a bunch of stuff to check if you're having WOT problems.
I'd go with stingray's advice and double check everything you did..... I know with me it's always simple stuff that screws me. Good luck!!
Ayuh,... If it ran Great before ya fixed it,...
And it Don't now,... Ya screwed up somewhere...
Bt Doctur
no load, it will red line in rpm with 2 dead cylinders. Check the plug wires in relation to the firing order.
Bbeaz425
I have a 1991 4.3L that is doing the exact same symptoms (only i didn't change parts) it just started occurring. Please respond to this thread if you pin point your problem, it may be the same issue with me. Thanks!
Bt Doctur
B, you really should start your own thread so your question dosent get lost.
Start by changing parts like a full tune up, check/replace all filters. Inspect prop for bent blades.
Compression test would be next.
