1990 Merc 40 hp 4 cyl 2 stroke oil pump ?
corm
Greetings,
What material is the oil pump grear on the crank shaft made of?
Is the key locking it to the shaft a soft key like in a lawnmower flywheel key?
Is the oil pomp itself rapirable at all? It seems to be stuck and will not turn in one direction and when it turns in the other the shaft seems to move outward every 180 drgrees then back inward. If You take the oil seal ou can you then dissemble the oil pump from there?
Thanks,
Faztbullet
Re: 1990 Merc 40 hp 4 cyl 2 stroke oil pump ?
A hard nylon material....
Standard "D" key , never seen one sheared if thats what your thinking....
No as no parts are sold seperately,replace as a assy only.
corm
Thanks Faztbullet,
Do you or anyone think that a frozen, probably rusty, oil pump can be disassembled and repaired?
I know it is probably easier to find a take off or used one. I just like to tinker these days.
Faztbullet
I guess you could but I would not trust, as if it is pitted internally if could change the oil flow ratio...
