1990 Merc 100 HP Full throtle bogging of the engine
icesk8s
1990 Merc 100hp inline 4cyl<br /><br />Problem: When accelerating from start the motor runs fine. After about 10 seconds the motor throttles back to about half power (will only pull about 3000rpms)or sometimes throttles back even further. If someone pumps the ball it goes back to full throttle but only till the pressure in the line runs low then it throttles back again. I have changed the fuel line to the gastank and it does the same thing with both lines. <br /><br />Note: If i go from start and set the power at about 3000 rpms the motor will run like this without problem. <br /><br />Any ideas? Fuel filters? plugged carbs? Any tips would be greatly appreciated.<br /><br />Scott
achris
More fish than mountain goat
Re: 1990 Merc 100 HP Full throtle bogging of the engine
Ice,<br /><br />Welcome to iBoats.<br /><br />When was the fuel pump last rebuilt? They should be done at least every other year. I do them on the annual service. Really easy to do. The kit number is -42909A4 if you have a 90 degree check valve (into the fuel pump) or 21-857005A1 if you have an in-line check valve.<br /><br />Chris............
icesk8s
Originally posted by achris:<br /> Ice,<br /><br />Welcome to iBoats.<br /><br />When was the fuel pump last rebuilt? They should be done at least every other year. I do them on the annual service. Really easy to do. The kit number is -42909A4 if you have a 90 degree check valve (into the fuel pump) or 21-857005A1 if you have an in-line check valve.<br /><br />Chris............
Thanks, i will give this a try. I don't think we have ever done this to our boat. Any idea of how much something like this would cost?<br /><br />Scott
achris
Scott,<br /><br />Try this website. (diaphram kits are really cheap, 'bout $11)<br /><br /> http://www.mercruiserparts.com/partsbynumber.asp <br /><br />The kits aren't the same so make sure you get the right one. If you don't you'll destroy the engine!<br /><br />Chris............
Keith Buchanan
Hi Scott.<br /><br />My 50hp is doing exactly the same as yours, with advice from Chris and the other great Guys on this site I have got on order a fuel pump kit, I,ll keep you posted.<br /><br />Keith B... :)
icesk8s
Thanks, i'm going to try the same thing with the fuel pump kit
icesk8s
Originally posted by Keithy B...:<br /> Hi Scott.<br /><br />My 50hp is doing exactly the same as yours, with advice from Chris and the other great Guys on this site I have got on order a fuel pump kit, I,ll keep you posted.<br /><br />Keith B... :)
Is there anywhere that can shoe me how to do the repair? I have never done it before.
achris
Scott,<br /><br />It's real easy. Disconnect the hoses from the pump. Should be 3, fuel in, fuel out, and crankcase pres/vac. If there's a 4th, that'll be oil in and you need the -42909A4 kit. <br /><br />On the pump you'll see 4 screws. 2 go all the way through and hold it to the block. As you loosen them you'll work out which ones they are. Remove the pump from the engine and put it on a CLEAN rag on the bench. <br /><br />Remove the 2 remaining screws and carefully take the pump apart, noting the positions of gaskets and diaphrams. The gaskets and diaphrams also have notches on one edge. This lines up with the notches cast into the covers and body of the pump. Inside the body are the valves. The kit has relacement valves, and they may look different to the ones in the pump. Merc changed them a few years ago. Put the new valves in and start reassembling the pump with the new gaskets, springs and diaphrams. I find it easiest to put the front cover on the 2 screws and put it facing up on the bench, then just 'drop' each section onto it. Nip up the screws and refit it to the engine with a new mounting gasket. It's important not to get this one upside down too, it's the other pres/vac for the diaphram. Re-plug the hoses and at this point I put a new filter in as well. Sits between the pump and the first carb. Volia! Done!<br /><br />Chris............
icesk8s
Wow, thanks for the help everyone. When i'm in Perth next year i'll have to come stop by and buy you a beer. One more question though...is there any way that i have to drain the fuel?? Or should i just pull the line off when it's running??
achris
Scott,<br /><br />Common question. With older, non oil-injected, engines it was ok to run them out of fuel. With an oil-injected engine that is an absolute no-no. If you disconnect the fuel line with the engine running since the pump is still running and only being supplied with oil the carbs will be filled with oil.<br /><br />The next time you go to start the engine all that's in the carbs is oil, nothing to 'fire' on. When it finalled gets some fuel in the there and starts running there is going to be a huge cloud of smoke.<br /><br />When you're here drop me a line and we'll go out and kill a fish or three.<br /><br />Chris.........
icesk8s
Originally posted by achris:<br /> Scott,<br /><br />Common question. With older, non oil-injected, engines it was ok to run them out of fuel. With an oil-injected engine that is an absolute no-no. If you disconnect the fuel line with the engine running since the pump is still running and only being supplied with oil the carbs will be filled with oil.<br /><br />The next time you go to start the engine all that's in the carbs is oil, nothing to 'fire' on. When it finalled gets some fuel in the there and starts running there is going to be a huge cloud of smoke.<br /><br />When you're here drop me a line and we'll go out and kill a fish or three.<br /><br />Chris.........
Cool, will do. Thanks
Keith Buchanan
Hi Scott. <br /><br />Just done a river trial tonight after a fuel pump kit and everything is back to normal, diaphram did not appear to have any perforations but was a little stretched and saggy. Hope you are getting to the bottom of your problem.. PLS post and let us know how u r getting on..<br /><br />Best of luck ..Keith B..
achris
Hi Keith,<br /><br />Good to hear you're got your water wings back.<br /><br />Chris........
