1990 Johnson Vro reverse problems.
CNRsturgeon916
I own a 1990 Johnson 60hp Vro Friday when I went to put it into reverse pulling into the dock it clanked around for a second before engaging then went into gear. Didn't slam into gear or anything crazy. So Sunday I went back out and it did the same thing when I left the dock. Well when I got to the fishing hole I hit reverse to set the anchor and it wouldn't engage at all. Just a ruff clanking noise. So when I got home I pulled the linkage under the hood and fired it up with the bunny ears on and tried to put it in reverse by hand and it slams it outta gear faster than you can get your hand out of the way
emdsapmgr
You've done a nice test. Disconnect the shift linkage at the engine end, and shift the lever by hand while the engine is idling: if it shifts normally by hand, then that's normal. Likely the problem is with the adjustment of the shift cable at the engine end. You'll need to place the engine in neutral, then line up the shift cable eye with the stud/bolt on the shift lever. You may need to turn the thumbwheel on the cable in order to get the cable eye to move/align with the shift lever stud end. Once they align, reinstall the cable and nut.
emdsapmgr
I failed to mention that when you are adjusting the control cables, that both the control box and the engine's shift lever both need to be in neutral.
Also check for play in the shift cable, they do eventually wear out. If there's enough slop in the cable it could certainly cause problems getting into gear.
CNRsturgeon916
Well I played with cable adjustments and it changed nothing. So I disconnected the linkage completely and tried again by hand under the hood and drive works fine by hand but still the same with the reverse. Kicked outta gear so fast it destroyed my knuckle
emdsapmgr
When you pull the lower unit off, you should first check the setting of the shift rod. Possible it's not set correctly. Then get into the gearcase.
Did this problem appear out of nowhere, or is this a new to you engine?
If it appeared suddenly (and this is a longshot) check to see if there's anything blocking movement of the shift linkage.
