Re: 1990 Johnson v6 200 gt
Assuming that the engine has run normally in the past (idling, shifting, etc), and nothing has been distrubed, the cause is normally a lack of rpm/power.
First thing to do is to check the compression and spark..... Compression = 100+ psi and even on all cylinders? S/Plugs removed, check spark = Jumps a 7/16" gap with a strong blue lightning like flame... a real SNAP?
If the two above areas check out okay, suspect a fouled carburetor which would cause a cylinder to run lean.
