1990 Johnson GT150 assembly help!!
heaterguy
Ok so I just got finished re assembling my motor, new bearings, pistons, rings, etc. Book says to temporarily install flywheel after torqueing of crankcase halves to check for binding. There is none, spins nicely. Next step is to torque down the upper and lower crank bearing retainer bolts to 96-120 in. lbs. Once this step is performed the engine will not turn at all. I found as soon as the lower crank bearing retainer bolts are slightly more than finger tight the motor is locked up completely. I removed crank seal and reinstalled plate and still binds, removed new crank bearing and reinstalled old bearing, still binds. flipped the round 4 bolt bearing retainer over and still binds. What am I doing wrong??
emdsapmgr
The lower crank bearing housing has two sets of bolts. The shorter ones are the ones that bolt the bearing head to the crankcase halves. These bolts are usually pretty straight forward during assembly. The other (longer set) bolts extend up through the bearing head and engage the lower bearing retainer plate. It's possible that during your tightening of the bearing retainer plate that the clamp load is not even on the bearing. That could provide some distortion/binding to the bearing when it rides on the crank. Did you use two OMC guide pins (383175) when sliding the head onto the crankcase? That helps with the alignment.
heaterguy
I made a set of alignment pins out of 3" long 1/4 -28 bolts that I cut the heads off of. I know I am using the correct bolts as I bag and label all parts. The 4 longer center bolts that hold the retainer I can torque down with no binding. The binding occurs when I install the bolts that thread into the crankcase halves. I've tried different methods of tightening then, torquing them in stages making sure everything goes together as evenly as possible, no matter what I do I end up with a bind so tight I can't turn the motor, if I loosen all the bolts that thread into the crankcase the motor turns freely. I'm at a loss here.
emdsapmgr
Was the engine ever overheated? What does the lower crank ball bearing look like? Does it appear blue at all? Is the lower bearing head flat to the surface of the block? Sounds like it's not seating flush.
heaterguy
Lower bearing is new. I was able to get a feeler gauge between the bearing head and block about 0.050" from flush. I ended up splitting the case apart and found that the crankshaft wasnt exactly centered in the case, when I tightened the lower retainer it would cause the rod ends to bind against the crankshaft. I reassembled (cleaned halves and new gel seal) a little differently than the manual says, bolted crank heads first, then torque the halves together in several stages checking for binding each time. Then the locator pins followed by the perimeter bolts. Motor spins nice and free with no signs of binding. I just wish the manual gave some mention of this as I followed it to the t. Thank you for the quick replies.
