1990 Johnson Evinrude 120-TLAS VRO RPM's?
Gashette
I don't usually use blogs as I have not ever had much response, but having read through this site at great length the last few months it looks like some of y'all really know your stuff! So here goes:
I have a "Frankenstein" Bluewave 220V CC (22 foot) we rescued from the bottom of Galveston Bay after Ike. We have completely restored the hull, and by that I mean stripped down to nothing- new fiberglass, new cabling, new fuel tanks, new gel coat, new center console- you get the idea.
The motor- 120-TLAS VRO was "given" to me by some friends who lost their boat in an unfortunate "traffic accident" (don't ever forget to put the leash and chains on when it's trailered!).
I have had the motor completely re-built and serviced by a real marine mechanic (not a shade tree guy, but the real thing with certifications and pretty papers on the wall).
The VRO system was disconnected/ bypassed during this process as we weren't sure if it was A) going to hold up much longer, B) worth the worry.
The motor runs like a champ! No problems whatsoever- BUT, at WOT I am turning MAYBE 4800-4900 RPMs on a good day. The prop that came with it is a 15 1/4 x 18 Stainless Steel Rampage, which the previous owner had re-pitched to a 16. Having read extensively through this forum, it was obvious I needed to re-pitch yet again (200-400 RPM per 2" pitch lower is my understanding?). Also, my understanding is this motor specifies 5600-5800 WOT.
With that in mind I had it re-pitched to a 15 and was told it could not go any further without compromising the strength.
I had expected to see an additional 200- 400 RPM, but no luck. And here's where it gets very interesting- prior to having it re-pitched (when it was a 16) I would turn just a hair above 5000 and sometimes 5200 with the wind at my back. So, I actually LOST RPM after I changed it?!? Prior to the change I pushed about 20- 22 knots max (on the GPS) at WOT and now even with lower RPM issue I am pushing 24-26 knots (same GPS).
In neutral, I can rev the RPM almost to the rev pack limit of 6700 RPM leading me to believe it's not the throttle linkage preventing my reaching WOT?
Should I try a new prop? Is it common and or possible the work I had done is wrong? How can I tell?
Before dropping another few hundred on a new prop (15 1/4 x 13 or 14) I would really like some "no kidding" ideas on what it SHOULD be versus what my buddies THINK (easy for them to say when they don't have to write the check!).
