Bonstrosity55
Thread starter- Joined
- Jul 5, 2015
- 8
Hi all,
I recently finished swapping the powerhead on my Johnson 88 SPL. I have started the motor twice on muffs to let it run and break in. With very little trouble, when it ran, it idled as it should. When I brought it to the lake to continue the break in process I could not get it to start on the water, in fact it didn't even fire. I brought it home and have not been able to get it to fire or start it since.
Troubleshooting: I have double checked that I am getting bright blue spark on all 4 cylinders and that I have compression across all 4 cylinders (115 x 4). This leads me to believe all of the ignition components are still functioning and that I have 2 of 3 components to get it to run. I checked and the flywheel key had not sheered off. I'm looking for suggestions on what could have happened since the last time it ran. I may try fresh gasoline as the stuff in the tank is about 4 months old, however I would think it would still fire even with a little bit older gas.
